Goedemorgen Hans,
Welkom op dit forum.. Zou je ook de moeite willen nemen om je even voor te stellen in onderstaand topic? Aangezien we natuurlijk allemaal nieuwsgierig zijn welke Up! je in bezit hebt.
http://vwupforum.nl/viewforum.php?f=3
Wat betreft je tankklep..
Removing and installing tank flap unit
Removing
Note:
- The tank flap unit may be engaged in side panel with 1 or 2 locking hooks.
- Accordingly, there are 1 or 2 markings on the tank flap unit.
- In the illustrations the version with 1 locking hook is shown.
Carry out following work:
– Screw off tank cover.
– Insert a screwdriver -2- into the marked opening -3-.
– Release locking hook -arrow b-.
– Swing tank flap unit -1- out of side panel -arrow c-.
– Guide water drainage hose -4- together with tank flap unit out of side panel.
- up-502.png (241.34 KiB) 21997 keer bekeken
Installing
– Insert water drainage hose -3- through opening in tank flap unit -1- and then pull it through as far as it will go.
– Push water drainage hose -3- into side panel.
– Swing tank flap unit -1- into side panel and pull sleeve over filler neck.
– Then insert tank flap unit into side panel completely. Make sure that locking hook -2- engages correctly in side panel.
-->> Perform functional check of release components.
- up-503.png (215.36 KiB) 21997 keer bekeken
